I recall an interview with Julian Vereker on US radio in the early 80s in which he likened the LP12/Ittok/Asak to a telephone pole a mile long with a log splitter on the end and a record groove a couple of inches wide. He was emphasizing the quality of a rigid coupling between the three. Of course, he conveniently omitted the "lossy" connection between the LP12 armboard and the subchassis, effectively negating all the theory............If you look on the web you can see scanning electron microscope photos of the stylus in the groove. They will show you how incredibly tiny the wiggles in the grooves are and how little of the (already very small) diamond actually touches the vinyl. When you see this it starts making sense how any small vibration reaching the record from outside will disturb the ability of the stylus to be shoved around by just the groove. Vibrations from the turntable main bearing, which has the difficult task of allowing a smooth, non-varying circular movement of the platter with no movement in other directions (wobble, uneven rotation, up and down motion, etc.). Vibrations from the motor which has to transfer consistent power to the platter without transferring any self-created wobble or vibrations.
As a guitar player, I was/am flummoxed by Tommy's skills. Then I saw the movie "Men In Black" and it all made sense.....Doing it’s thing on a wonderful album to test its strengths.
One of only 5 guitarists in history to be awarded the Certified Guitar Player (CGP) accolade.As a guitar player, I was/am flummoxed by Tommy's skills. Then I saw the movie "Men In Black" and it all made sense.....
I’m 31 hours into the monster cartridge that is Ekstatik now and it just gets better and better and better.
Conventional wisdom points to a run in period of 50-70 hours so, if true, I still have more improvements to come. Yikes - that’s definitely something big to look forward to.
A wonderful cartridge mated to the Ekos SE (and so it should be too)
Glad you are enjoying your Ekstatik. I did wonder how much the one I had on home-dem might further improve, as it had only done around 20 hours when I began the trial.I’m 31 hours into the monster cartridge that is Ekstatik now and it just gets better and better and better.
I'm still waiting delivery of my Etna SL, ordered nine weeks ago.
bt, what's that stylus timer thingy?
Mine improved significantly after 100h. Heights become less emphasized. At the beginning I was amazed with the level of details, resolution, “air between instruments” etc. But soon after, high resolution started to annoy me. Now, after cca 200h it’s much more musical and better balanced, more natural. I also don’t have any problems with skipping, which I had from start. I spoke with Linn guys at the Munich hi-end show about that not so brilliant experience, Gordon from Linn told me Ekstatik suspension needs at least 80h to burn in - to become more elastic. My old Krystal was a different beast, more Lyra like sound, more relaxed and soft.Glad you are enjoying your Ekstatik. I did wonder how much the one I had on home-dem might further improve, as it had only done around 20 hours when I began the trial.
En effet, pour diverses raisons, certaines cartouches neuves méritent plus d'heures de rodage. Je me souviens que lorsque j'ai remplacé Akiva par Kandid, j'étais déçu ; un ami a fait le même constat. Le nouveau Kandid était plus sec et plus net avec des basses plus faibles, l'Akiva sonnait plus mélodique. Petit à petit, Kandid s'adoucit et dépasse Akiva après 80/100 heures. Je pense que cela peut être pour Exstatik.
If there is something like a Lyra sound, how can a Krystal from Armour/Goldring can do this?Mine improved significantly after 100h. Heights become less emphasized. At the beginning I was amazed with the level of details, resolution, “air between instruments” etc. But soon after, high resolution started to annoy me. Now, after cca 200h it’s much more musical and better balanced, more natural. I also don’t have any problems with skipping, which I had from start. I spoke with Linn guys at the Munich hi-end show about that not so brilliant experience, Gordon from Linn told me Ekstatik suspension needs at least 80h to burn in - to become more elastic. My old Krystal was a different beast, more Lyra like sound, more relaxed and soft.
It would be very nice if you use English (or a kind of like I do ) like all the other members do.En effet, pour diverses raisons, certaines cartouches neuves méritent plus d'heures de rodage. Je me souviens que lorsque j'ai remplacé Akiva par Kandid, j'étais déçu ; un ami a fait le même constat. Le nouveau Kandid était plus sec et plus net avec des basses plus faibles, l'Akiva sonnait plus mélodique. Petit à petit, Kandid s'adoucit et dépasse Akiva après 80/100 heures. Je pense que cela peut être pour Exstatik.
Many thanks in advance.
Ok, if you insist - let it be than just more “relaxed and soft”If there is something like a Lyra sound, how can a Krystal from Armour/Goldring can do this?
Je suis désolé si la traduction Deepl ne convient pas.Ce serait très bien si vous utilisiez l'anglais (ou une sorte d'anglais comme moi ) comme tous les autres membres de la police.
Merci d'avance.
Ben, what do you have against la France?
Hum?
How good is Ekstatik? It's so good and resolves so well that non French speakers can understand French music fluently.
I think that's what this thread is trying to tell me.
@Chris 1970 #16 „Erra Settembre“ is a good piece to decide between fibre and copper. Looking for your feedback.
But it seems, we‘re a little bit off topic.
Similar threads
- Replies
- 70
- Replies
- 89
- Replies
- 95
- Replies
- 11
- Replies
- 4
