Wanted 21vAC Power supply
Wanted
tidywires
731
47
58
Cloughton N.Yorks
Looking for a power supply for my Lehmann phono stage, the one with it is just the "wallwart" and makes a buzzing noise.
Anybody got a nicer one? Thanks....
Firebottle
313
304
The Black Country
Alan
If it is AC then the wallwart will just be a transformer. As Lehmann are german made I wonder if the transformer is more suited to 220V mains?
I think I have a 20V AC wallwart that is rated at 240V input.
tidywires
731
47
58
Cloughton N.Yorks
Yes def 21v ac - and yes Firebottle I think you could be right ref 220v despite labelled as 240. I will check it in a different location as the socket is mounted in a boarded wall which might be adding to the noise!
mj446
1,310
178
Fife
Martin
Looking for an original wall wart too, Lehmann specs are 230v in 21v out, I’m using a ‘large’ aftermarket unit at the mo, 240/19v but space is at a premium, anyone?
brandonfin
