Someone will be along in a minute, I'm sure, to talk about first and second unfolds!
There does appear to be quite a bit of confusion. There is a Bluesound community thread about the Gustard DAC in this context but much might be more widely applicable. Scroll down to the post from 12m ago headed SOLVED.
I read the Gustard post and it seems you need to disable the MQA DAC option on the Node:
“While this DAC is capable of fully decoding and rendering MQA, it can do so via USB. If this is fed with signal via coax or optical, in order to enjoy the hires quality of MQA, the first unfolding must be done by the source. In my case, it is a BS Node 2i which has an option to send raw signal (without any unfolding) to the DAC by enabling "MQA External DAC" option in the BluOS. However, when this option was on and transmitting the raw data to this DAC, the DAC wasn't able to fully process the data and incorrectly display the format as well as the sample rates of ALL songs that I was testing. Only when I turned off "MQA External DAC" option, the DAC was then able to pickup the signal and process it properly and display the format/sample rate correctly
I have confirmed this by turning off "MQA External DAC" in the settings of BluOS and while playing a MQA album showing the MQA logo with the green dot in BluOS, the Gustard X16 displayed the higher bit rate of the MQA recording that did not appear when I had "MQA External DAC" turned on. Now I am confident that a true MQA signal is being output to my amp.”
However that is because it needs the first unfold if using optical or coax. Not sure about my DAC. all very confusing and my Tidal sub has now finished.
If using Qobuz best to disable MQA setting on Node?
Edit: it seems my Soncoz DAC only can do MQA on usb input, unless first unfold is complete on source, this seems common on most DACs, so I’ve had my Node2 on the wrong setting, probably why I can’t hear any difference. Bluesound need to change their information.
