Sorry but 'blows away' isn't a parameter that I can understand. Your 'blows away' could well be my 'meh' so unless I can find some way of comparing items that isn't in the opinion of the listener, I really don't bother.As i said you have to listen.I have a Wadia and it blows away anything i have had before .
Absolutely right.....to both machines being compared, one immediately after the other, at the same volume, unsighted.As i said you have to listen.
why demonstrate nothing then.Absolutely right.....to both machines being compared, one immediately after the other, at the same volume, unsighted.This usually eliminates much blowing away
If anyone has a high end CD player I'm always happy to demonstrate this amazing phenomenon.
I would love it if a dealler could show, in a properly conducted blind level matched test, why their CD player was better than a Tesco CD player. That dealers never try this suggests that they can't.why demonstrate nothing then.I prefer dealers who can show me why I'd spend all the money on, say, a rega apollo, when a Tesco CD player will do just as well.
Lucky You! If I can't measure an audible difference, then as far as I'm concerned there isn't one. I find it rather interesting that all those 'night and day' differences disappear when the comparison is done blind and level-matched. Funny that!So is cd sound only about distortion levels and flat response?Nothing else matters?
Damn! Even using the same dac (weiss DAC 202) and changing transports (one is a cd-p, other one is a laptop) I can tell the difference!
I have a £30 ASDA DVD player, will that do? Indistinguishable from my Meridian.For all the huff and puff I cannot see any Tesco cd players in members kit lists. :roll:
I don't. I use my SBT as standard, analogue out as I do the rare times I use the cd player. The pre-amp analogue out goes through the Behringer DEQ as an ADC then on to the DCX crossover which then has 6 analogue outs to the power amps.night and day... difference is more like - mmm yeah
- I really like that.
Anyway... I might be a misguided fool (way more reasons that a mere dac to be one ) , but this begs for an answer Serge:
how come you have a cd-player and a dac?
Just curious as to why you use the Meridian in preference to the ASDA DVD player if they are indistinguishable in your system?I have a £30 ASDA DVD player, will that do? Indistinguishable from my Meridian.
S.
I was kidding mate!I don't. I use my SBT as standard, analogue out as I do the rare times I use the cd player. The pre-amp analogue out goes through the Behringer DEQ as an ADC then on to the DCX crossover which then has 6 analogue outs to the power amps. The only separate DAC I used is a Behringer UCA202 on my old laptop into Genelec actives for my holiday system. The old laptop had some noise which the USB DAC eliminated. My new laptop is quieter, so I probably won't bother with the UCA202 in future as the laptop's analogue output seems fine.
S
Because the Meridian fits the rack space I made for it and integrates with the pre-amp and tuner remote control.Just curious as to why you use the Meridian in preference to the ASDA DVD player if they are indistinguishable in your system?
Right indeed. The CD format is transparent, and the CDs themselves, if not everlasting, should have a very long lifetime. My CDs from the early 80s still play with no wear, unlike tape or LPs that both have significant wear mechanisms. That the CD format has been abused by the record companies is no fault of the format. It does provide pure perfect sound, and if not forever, for a very long time.CD Perfect Sound Forever TM Philips.Yeah right.
