I bought this in May, direct from Audio GD. I chose it because I have an R2R DAC from the same company, and it's a stunning piece of kit. This headphone amp is also excellent for the money, but I just don't find the time to listen to music through headphones.
Blurb from the website:
Class A design built by discrete analogue stages without any OPA or coupling caps in the signal channels.
2 pair accurate matched 20W (in total 80W Pcm) output transistors.
Non- feedback ACSS and output stage designs
2500mW at 25 ohm Pure Class A, drives most headphones working in pure class A
ALPS-27 hifi grade volume pot
14DB and 20DB gain can drive the high and low sensitivity headphones
3 groups input: RCA X2, ACSS X1
Preamp output : RCA
Headphone amp output: 6.3mm
Headphone amp Output Power (Pure Class A):
25 ohm: 2500MW
40 ohm: 1600MW
100 ohm: 650MW
300 ohm: 325MW
600 ohm: 160MW
Note: there is an imperfection in the paintwork on the right hand side of the amp, which I have tried to pick out in the photo. I've only just noticed it when taking photos, so I assume it was like that when it arrived.
Location = Colchester. Price =£200 £180 + £10 postage to mainland UK.
Preamp output : RCA
25 ohm: 2500MW
40 ohm: 1600MW
100 ohm: 650MW
300 ohm: 325MW
600 ohm: 160MW
