I have just bought another Benchmark DAC; this time a DAC2 HGC. I also have ordered another pair of Neumann active monitors to use with it. But I also have a wonderful pair of Harbeth P3ERs that I will use. I am currently using a Quad 909 which sounds fine although to as good as the power amp section of my Marantz PM11S2 and am thinking about whether to get a different power amp.
Given that Benchmark favour using the XLR outputs I am wondering if there is a big difference between using the XLR outputs vs single ended and does it make more of a difference if the receiving amp is 'just xlr input' or a proper 'balanced xlr' input.
Thanks
Thanks
