Strictly speaking, and to be blunt, a collection of 20 assorted mono records is insufficient to justify the outlay you would need to beat just playing them with a stereo cartridge.
Having said that, I'm a convert having gone the whole hog with a Miyajima ZeroB cart and a dedicated single generator phono stage. And I recommend that you visit the record fairs in your area and pick up some dirt cheap mono records and build a collection and work towards something similar.
Based on your musical tastes and pocket you need to choose whether to go route A or route B:
1. Route A is to pursue reissued monos and buy a 0.7 mm diameter diamond in your mono cart;
2. Route B would be to pursue earlier mono recorded on older recording equipment and opt for a 1mm diamond.
(Jazid explains the difference above.)
In my case I'm a jazz fan and as the original 50s Blue Notes etc., are beyond my reach financially, my jazz collection tends towards affordable reissues.
So I chose the .7mm ZeroB. There is also a 1mm Zero available for the older stuff.
Finally, do some research on the concept of 'true mono'. That is, a single generator cartridge rather than a stereo cartridge 'strapped' for mono. A starter cartridge I would recommend is an AT33PTG mono. This is an affordable MC which will play into a conventional MC input and a conventional meat and potatoes hifi system. Ortofon also have a range of mono cartridges they brought out to coincide with the AbbeyRoad Beatles mono box set.
You find that many mono enthusiasts, such as Montesquieu on here, use arms with removable headshells to facilitate changing from stereo to mono, or, indeed, mono to mono if they have both 0.7 and 1mm.
Bon voyage..
Jack NSM
