Best phono amp for under £300?
linnmike
28
Over the rainbow..,
I'm looking for a new phono amp to go with a Michell Technodec in a bedroom system. Don't really want to spend more than £300. Cartridge is a Goldring G1042 moving magnet, amp an Arcam Alpha 8R. Any suggestions?
dudywoxer
10,222
1,256
sunny scunny
colin
If you want to spend lots less, and not miss the mark by very much, the Gram Amp 2 SE is very good, and the little cambridge audio 640p is astounding for about 3 quid.
sheldon5
25
Durham, , United Kin
Isn't the 640P similar in price/performance to the Project Phono Box or better? I've been surprised with the performance from the Slee 2SE, now looking to get the PSU upgrade but not sure if the difference would be noticable.
dudywoxer
10,222
1,256
sunny scunny
colin
The 640 is streets in front of he Phono box, I think its about £60.
stormyuklondon1
915
184
58
Scott
i'm currently using a heed mm phono amp with my gyro/techno-arm/dyanvector 10x5 until my dynavector p75 mk2 turns up, and i can highly recommend it. bloody bargain when you consider its £225 aswell!
TIU
Artist and daft as a brush
13,654
7,751
Birmingham
Gary
Having had use of the Trichord Dino to compare with the Pro-Ject Phono Box SE, I would say the Dino is a very worthwhile investment. But get the Dino+ (plus) with the separate PSU.
linnmike
28
Over the rainbow..,
Thanks for the recommendations. I called Audio Affair this evening based on what you said (for some reason they are open until 9 every day) and they were very helpful and did me a good deal on the Dino..also picked up some 180 gm LPs with it, so went a little over budget, but hopefully it'll be worth it (and its Easter after all). They also have the PSU upgrades, but the never connected version (http://www.audioaffair.co.uk/index.php?act=viewProd&productId=378) costs so much more than even the Dino so I'm sceptical it would make a difference. In any case, looking forward to seeing how the Dino fares when it arrives!
Chumpy
14,040
112
Although I have tried many, the best one is IMO the one that comes within obsolete Marantz PM7200 (MM normal parameters solely).
I agree that it is possible to believe anything, and that in Naim context I can enjoy Naim Stageline.
johnnyesox
541
Outside Paisley now,
Yip, Trichord Dino for that T/T is the way to go... even better if you get it 2nd hand,what you save, keep for the Dino + upgrade,this will take your Technodec into another league...[honest!]
rockmeister
18,004
745
Scotland
hope you enjoy it.
No members online now.
