This follows on from my K&K phono stage build.
http://www.hifiwigwam.com/forum19/14937.html
I'm doing some testing and getting nowhere. Kevin's on holiday for afew of weeks so I'm asking for some Wampower.
Having completed my build I was ready to start my testing. Here's a snapshot of where I got to;
With all valves in place andthe time delay switchdisconnected, I turned on the amplifier.
The valves glowed gently and the blue LED lit into life. I then measured the voltage across the tubes and they were inthe upper end of the expectedscale.
I turned off and fitted the time delay switch.I switched on again and waited for the click to tell me the time delay switchhad kicked in.Nothing. Except I noticed that the fuse had blown.
So,I removedthe switchagain and replaced the fuse witha spare. I then switched on again (remember this was fine before) and the blue LED lit for a fraction of a second before the fuse blew again.
I then tried disconnecting some wires from the 10VAc/Fil connections on the main board and the first resitor in the circuit as well as the rectifier tube on Kevin's instructions. Some times the fuse blows and some times, it doesn't...
The result of all this testing is that I have an intermittent catastrophic failure somewhere that appeared to start when I first installed the time delay switch and continued after its removal.
Kevin's instructions before he left on vacation are to check that I don't have any solder joints where I shouldn't on the main board. Of course I'll check that. (there's none on the top of the board.)
Can anyone offer any other suggestions?
One question, When I solder compenents from the bottom of the board, is it vital that the solder bleeds through to the top of the board to make a proper connection? Some of mine (a lot if I'm honest,) do not.
I know this is a bit vague but any pointers gratefully received?
Any experts near Edinburgh who would like to assist, I'm more than happy to make dinner/buy beer. I'm a pretty good cook!
Thanks
Thanks
