As some of you know,I have two AVC amps, both EL34 models but the first one I bought came fitted with KT66's and biased accordingly. I duly bought another because it was cheap and I happen to like them. I decided to fit that with KT66's also and whilst waiting for two new sets of valves to arrive thought I'd chuck in a spare set I had lying around as a starter. Checking the specs for the KT66 I find the anode dissipation to be the same as the EL34 at around 25 watts. To me that makes all the maths come out the same so I should just be able to put the KT's in and leave it at that or am I missing something?
