Probably not a million miles off the Yamahas I think I bought off you?
I bought the Yamaha’s from you Lawrence, yes similar technology I think.Probably not a million miles off the Yamahas I think I bought off you?
Barely used, they're minty.Those xs edition new jerry .
I'd be looking at a well priced, and well made, replacement from Amazon. Then compare to your current cable, if it sounds the same you're quids in, if it sounds worse then you'll only have lost £20 approx. and you can consider more expensive 10ft cables.Hi guys, I’m looking for a bit of advice.
Due to moving things around I now need a 10ft cable for my Hifiman 400i (not the revision model).
I currently use a Moon Audio Blue Dragon cable but a 10ft version is a bit pricey. Suggestions welcome.
Here you go, £13 including delivery. If nothing else you'll end up with a spare stop gap cable should a more expensive cable get damaged in the future.Hi guys, I’m looking for a bit of advice.
Amazon product
How about this one:Thanks for the link, but it seems that it doesn’t fit my version off the 400i?
- Note:this cable has Dual 3.5mm male connector that be putted into headhone plug, it only Compatible with Hifiman Sundara, Arya, Ananda, HE4XX, the latest version HE-400i with both 3.5mm plug headphones, it doesn't fit the old version HE-400i headhone with both 2.5mm plug
Or even this one, cheaper at £11.99 including delivery:Thanks for the link, but it seems that it doesn’t fit my version off the 400i?
ps all three of the links (two of which I think will fit your HiFiMans) above are from the same manufacturer as I bought for my Nighthawk's. I've had no issues and the cable is still working years later.Thanks for the link, but it seems that it doesn’t fit my version off the 400i?
Thanks for the links. They have got to be worth a try at that price!ps all three of the links (two of which I think will fit your HiFiMans) above are from the same manufacturer as I bought for my Nighthawk's. I've had no issues and the cable is still working years later.
My Hifiman Edition XS saga continues.Uh oh.
Comfort issues.
Great when first put on, but a relief to take them off.
Maybe I'm wearing them at the wrong angle somehow.
The earcups seem large enough to encompass any feasible human ear, but the top of my left ear is getting sore.
It's all a bit baffling.
Investigations will continue.
