far too late to this I expect, but golden ratio always works sound wise, being one way of cancelling standing wave nasty stuff (excuse the technical jargon ), in which case 14 x 22 for an 8ft standard ceiling is perfection.
But firing across the short dimension complicates that if the speakers are huge.
Firing across the narrow bit always means that, speaker to you is a shorter way, almost nearfield so the best results in a small room are mini monitor type speakers, since you need to get the speakers out 2 or 3ft, and ideally you need to get your head away from the reflective wall just behind your ears, also 2/3ft AND damp that wall, which has the most effect (try simply cupping both ears with your hands while listening to see what occurs when reflections don't bounce around so much).
In your 14' you are only 8 ft from the face of the speakers. If 8 is fine, then read on.
Next big thing is to avoid a cube. I'm guessing a standard 8ft ceiling height, so don't double the 8. Go a bit bigger. I'd guess anything from 18 to 22 will be fine, and if you are doing speaker spacing on the standard triangle, that also might push you at least 3ft away from the corners so! Great.
Concrete floor with plywood sheet screwed/glued down (to take spikes) and then carpeted to aid damping.
Damping behind your head
Something at the 1st reflection points if you can, to break that up and job's a good un I'd think?
