I'd probably go for shorter interconnects and longer speaker cable runs then. Two reasons (a) metre for meter I think you'll pay more for interconnects than speaker cables or put it another way - better quality interconnects will have a bigger advantage than better quality speaker cables (b) longer interconnects give higher risk of noise.Single ended RCA interconnects. Probably talking about 6m
Can you explain why? I'd like to see hard evidence for that.The first thing to look at is the loudspeaker impedance curve. If it looks like a roller coaster track or has very low impedance at high frequencies (think Apogee) then shorter speaker cables are called for.
Just think how much quicker one speaker is getting the signal than the otherI like to live on the edge my speaker cables don't match lengthwise and i can't tell the difference.
Yes but last time my ears had a race the left one won so different cable lengths compensate...Just think how much quicker one speaker is getting the signal than the other
They're not impedance matched cables then?I like to live on the edge my speaker cables don't match lengthwise and i can't tell the difference.
Some of my speakers do as well, sort of! Mind you they are Quad electrostatics.My friend uses different internal length wiring in his 3 way speakers. To time align the drivers
Do those quads use different metal wires for different frequencies as well. If they don't, then they still haven't beat my friend at itSome of my speakers do as well, sort of! Mind you they are Quad electrostatics.
