Gotta do better on you're trolling. You're currently about 2/10 whereas Phil is in the lead with 8/10 due to his ability to back up his nonsense with pseudo science babble.First. This is not a faith forum. Therefore, do you think that "naysayers" have as much right to voice their opinions as anyone else? If yes, then what is the problem? If not then would you prefer unilateral moderation, and who should judge the criteria for that moderation?
Second. Please point out any question, sensible or not, being posed by the OP?
Third. If you can't find a question posed by the OP then which of the ensuing statements made in this thread meet your criteria of inanity?
And finally from the OP...
...ermm...
A class actYooooooooooooooou wouldn't let it lie...
Yes. Absolutely.First. This is not a faith forum. Therefore, do you think that "naysayers" have as much right to voice their opinions as anyone else? If yes, then what is the problem?
Try putting up a thread about fuses……..I hear what you're saying (and you obviously did come here to argue) but I've heard the same chat one thousand times over. I'm as skeptical as it comes about everything in life and I also thought people were mugs for buying cable since I used Van Damme XKE in my system. Until I took a chance and changed them out to OCC copper with better connectors I realised I was the only mug listening to a sub standard version of my system.
If anyone has any decent input I'd be grateful. I cant be bothered with condescending attitudes on a hifi forum.
Fantastic thanks George. It was infact the Puritian Audio Classic cable that made a substantial difference to my pre amp but sounded worse on power amp. This is the part that's bemused I have seen different cables, which are recommended for different applications. If you look up the cable you have on the website, it may help
You'll get creosote stains on your chino's for sitting so firmly on the fence Richard, Humpty Dumpty would be proud...I've got assorted mains cables here. All nailed together with my own (un)fair hands, using all sorts of wire. Lapp screened stuff, Belden, Kondo, Audio Note, Supra and 'ordinary' B&Q. I do use decent quality connectors, which I reckon probably make more difference than anything. I've also borrowed and tried some different ones that come at the sort of price that causes physical pain.
Is there any difference? Can't be sure. Therefore, if there is, it certainly isn't a substantial difference. Bear in mind though that all my source components use separate power supplies, built to be as immune as possible to external effects and interference, so that probably means the 'supply' will have less of an influence.
Like everything similar, there aren't going to be massive differences with any cable. With mains cables in particular. Thus, the cost/improvment ratio suggests spending silly money is pointless, as there are far bigger improvements to be found elsewhere.
No.Can’t suggest why the same upgraded cable would necessarily sound better on one amp, but worse on the other, sorry.
but I always screen as much of the mains leads as possible and also try to route them well away from audio cables and if they must cross, try to ensure they cross the audio ones at right angles.
as to noticing the difference, maybe?
I wondered what those stains were caused byYou'll get creosote stains on your chino's for sitting so firmly on the fence Richard, Humpty Dumpty would be proud...
Just noSorry, no to which bit?
Oh, thanks for the constructive suggestions, very helpfulJust no
You're welcome...Oh, thanks for the constructive suggestions, very helpful
Not 'bit' but part. A bitSorry, no to which bit?
You're welcome...
