Which settings? I don't see that sequence in the player settings (using Material Skin)Try Settings > Advanced > Streaming mode for HTTP(S) > select from the dropdown, click Apply
click on the "i" for info
Not finding it there either...Think it is in the server settings not the player settings .
Yes, cross-fade is set to none. I suspect this may be Qobuz rather than LMSOn LMS if you do not want gapless then under player settings - audio which under extra settings you need to set crossfade to None . Sorry if this is what you are already saying but just checked my settings and this is how it appears .
Honest!! I miss a simple word like "Network" out of the string and people complain. Where's me white stick?Which settings? I don't see that sequence in the player settings (using Material Skin)
Very strange.I do not get this with my Raspberry Pi using MoOde, but I do get this with my Nord easystream using Qobuz.
Still failing to connect the above to what I see on the screen - are you talking about settings in LMS (which in my case is via Material Skin) or some other settings...?Honest!! I miss a simple word like "Network" out of the string and people complain. Where's me white stick?
Try Settings > Advanced > Network >Streaming mode for HTTP(S) > select from the dropdown, click Apply
