I am selling this on behalf of a friend who is the original owner from new
SME Model 10
Turntable only, no arm fitted. £2200
Current RRP over £4000
Superb condition, apart from one small scuff on the lower side of the frame, and some marks around the holes for the arm guard. Packed in its original box and packaging. One owner from new. Purchased Oct 2009
Stock picture used for illustration but lots of photos to be added soon
Collection from Bristol BS7 or personal delivery within 50 miles by arrangement. Courier delivery can be arranged by as I will only send it fully insured the cost is likely to be around £120
The SME Model 10 precision turntable is built to exacting engineering standards providing reliability and freedom from critical adjustments. Build integrity, sophisticated electronics and vibration free moving parts allow the full capabilities on any sound system to be fully explored.The designer’s aim; a more affordable product, preserving as much as possible of the performance and engineering excellence found in the celebrated Model 30/2 ‘the best turntable of all time’.The Model 10 weighs more than 15kg (33lb) but is only Ø304mm, thus meeting all the requirements of high density construction on which freedom from colouration depends.The turntable is supported on three large polymer isolators within adjustable feet allowing quick and easy levelling.A cruciform sub-chassis carried on three polymer loaded towers. A novel design which affords impressive isolation without float.Fully machined extensionally damped platter, diamond turned top surface with a fine scroll finish for optimal record interface.Large diameter reflex record clamp ensures largest possible platter/record contact.Speeds: 33.3, 45 and 78 rpm.Polished stainless steel stylus guard.Soft dust cover to accommodate the turntable and arm, when not in use.Dimensions: 370 x 250 x 161mm (Record clamp fitted).Net weight with power supply: 16kg (38lb).Substantial packing case with internal fitments: 745 x 405 x 240mm.Shipping weight: 18.25kg (55lb)
SME Model 10
