Hi I was hoping for something under £1kWhat's inexpensive as they are good speakers?
Thanks I will look into that.Wonderful speakers ...not a valve amp but gato 150 is superb with focal .friend uses with 1028 .any reason you want valves ? The gato is class ab i think
Sounds good. I will look into that.A mate had these speakers and the Trilogy VTi sounded really good, tamed the top end a bit. Punchy and detailed. You should find one for less than £1k, but not many about.
I found the Gato 150 way too bright even with my ‘dark’ sounding speaker so dread to think how ear shredding it would be with Focals.Wonderful speakers ...not a valve amp but gato 150 is superb with focal .friend uses with 1028 .any reason you want valves ? The gato is class ab i think
Guess we are all different as at least 2 people i know use it with focalI found the Gato 150 way too bright even with my ‘dark’ sounding speaker so dread to think how ear shredding it would be with Focals.
The Gato 250 is much smoother, just a bit bland imo, but might be a decent match.
Puresound work well with most things, but you'd need to be careful about choosing one with enough grunt. The 2a3 is lovely, but would not have enough current to run Focals sensibly.Puresound amplifiers are supposed to work well with Focals......
