Have been running a Linn Ninka, AV 5103 and aktiv AV 5125 system. Very pleased. Source is mainly Spotify through CCA optical into the 5103 DAC and Mimik CD as a transport with coax digital also to the 5103. 5125 has the Dynamik power supply upgrade.
Came across a C5100 with Chakra power this weekend that I could not pass up as a possible upgrade. Was not sure what to expect but what I have found so far is less clarity and less detail. Not a bad sound and some may even prefer it to the separation provided by the 5125. Have been playing with the gain adjustment. The 5125 only has one adjustment while the C5100 has four. The cards in the C5100 have been installed recently and likely not played much. Have checked all connections inside units and they seem correct.
Will need to do some more listening and testing but would be interested to hear what to expect and any settings/adjustments/tests I should be aware of. And finally would the C5100 aktiv be considered an upgrade to the 5125 aktiv?
All thoughts and advice welcome.
