Linn Owners
Upgrade from Linn AV 5125 to C5100 - unexpected outcome
CJ1045
Krescendo HiFi Partner
433
277
Dorset, UK
Active bass cards often have a "lift" to the lower frequencies.  If you're using a Ninka card that has a bass lift for Ninka size drivers, your little Katan drivers may object.
The Katans are ported too where the Ninka isn't. Probably will sound fine though. I would just let my ears decide.
CJ
sunbeamgls
5,088
2,334
North Wales
CJ
All the more reason not to do it.  The sealed air in the Ninka will resist the driver moving, meaning more energy needed from the amp to make it move.
Whereas the Katan driver has very little to resist it moving so it will move much more easily (assuming equal free air efficiency of the drive units themselves), destroying itself quicker, if there is a problem to be concerned about of course. Katan cards come up quite often, so not sure why there's a need to take the risk.
Ninka passive = 50Hz
Ninka active = 38Hz so something is lifting the bass level a little
Katan passive = 75Hz
Katan active = 60Hz, not even down to Ninka passive level
Reactions: akamatsu
vicdiaz
188
153
73
Trujillo Alto, PR
Victor Diaz
IMHO to upgrade a 4 channel active AV5125 will require you to move to an active C4200 amp, an active C6100 will not cut it.
Einar
10
28
Oslo, Norway
Einar
Thank you all. Very helpful. Will test the Katans, carefully,  with chakt08 aktiv bass cards while searching for two chakt10 cards when I get around to it. For now the priority is to get comfortable with the AV5125/D v C5100 where I continue to lean towards my initial reaction that the 5125 is superior. This also seem to be the consensus.
Any guidance on how to best adjust the gain on the C5100 (4 dials)? I am finding the gain adjustment to be minimal until it mutes.
Tendaberry
LP12 Scholar
1,103
1,290
Hamburg
Lots of different opinions here. I had an un-Dynamiked 5125 with bi-active Ninkas for years and later exchanged the 5125 for a non-Dynamik 6100. The tri-active setup with 6100 was so much better, there was no way of going back. Adding the Dynamik to the 6100 is very worthwhile.
TooManyCatweazles
Vinyl Junkie with a DSM
951
915
Northern Germany
I seconded @Tendaberry already.
This morning an idea crossed my mind. Our usual mental model of an (ideal) power amp is, that it multiplies the input signal by a certain factor (gain). What if we change this for a moment for another model: A power amp connects the speaker with the power grid, and the input signal controls, like a variable valve, how much current flows from the power grid into the speaker at any instant. In the second model, the power supply would be clearly a very critical component of the amp's internal 'hierarchy'.
zephyr
76
74
38
Nelson NZ
Nice to hear about another person extracting what they can out of the Aktive Ninkas. I am  very happy with my 5125D into aktive Ninkas. Biamping the bass was better than splitting bass duities with 5125 and LK140. I remember when I had an earlier ADS into a Wakonda and aktive LK140s,  the limiting factor was clearly the Wakonda. I would just play music via ADS volume control instead, then upgraded to ADSM1. Never looked back on the upgrade path! The Katalyst upgrade to the ADSM is also a game changer.
I also now have possesion of another set of Ninkas which I am beginning to compare to my others with OW1 tweeters. I'll report back on another thread later on.
Einar
10
28
Oslo, Norway
Einar
Are you bi-amping or tri-amping the active Ninkas? I am still bi-amping with the C5100 to give it a fair chance but inclined to prefer the  5125/D. Plan is to swap the 5125 back in in a week or two to compare.
Looking forward to hear your thoughts on the OW1 tweeters. I am in a similar situation with two pairs of Ninkas. One pair with the original three-bar tweeters and one pair with the OW1 tweeters. I acquired them second hand and not sure if the OW1 tweeters were a repair or an upgrade or both…
zephyr
76
74
38
Nelson NZ
I have one 5125D it has a treble card and a bass card. The bass card is driving all 4  bass speakers .
Much better than having an LK140 with another bass card. I used to have 3 LK140s so tri aktive. 5125 more than capable of excellent bass to all 4 speakers. See my other post for my OW1 comparisons. Its very wet here in Nelson and so have indulged in some HiFi comparisons and put gardening on hold.
Einar
10
28
Oslo, Norway
Einar
Thanks. Seems we have different amp setup. My 5125/D runs 4 mono cards while the C5100 runs two stereo cards. I have yet to hear an ADSM1 but believe it’ has 3 generations or more of development on my 5103. Maybe one day….
Found your OW1 posts. Very interesting. Need to spend more time with my OW1s it seems. Re-auditioning and re-comparing equipment has surprised me before. Will take me some time though as the snow has just melted duty calls.
CJ1045
433
277
Dorset, UK
I think you have the cards the wrong way round in your writing. The 5125 takes two stereo cards and one mono card - no other option. The 5100 takes 5 mono cards, no other option.
CJ
Pennypacker
d^_^b
896
821
113
Netherlands
CJ
He could run chakt (mono) cards with an adapter in the AV5125 if I’m not mistaken.
Einar
10
28
Oslo, Norway
Einar
You are absolutely right. The stereo cards are in the 5125. Thanks for calling out the error.
Jail4CEOs2
1,997
1,291
Taiwan
LG G2 65 OLED
I do remember the scuttlebutt being that the difference between bi and tri amping was not profound.
