I'm not so sure in this case, The Exaktbox-I would make the key component of the ADSM (its Katalyst processor amd DACs) redundant, and replace it with an implementation which, though it is still Katalyst, is likely to be inferior. I haven't heard the comparison, but the process of squeezing Exaktbox functionality and eight channels of (less than full Akurate level) amplification into the standard case with a single power supply is bound to have produced some compromises.I suggest to listen to and evaluate a Akurate Exaktbox-I ... My opinion is that akurate system hub Exaktbox-I makes a lot of difference and you have katalyst...
In this case, I'd be inclined to recommend the route I myself followed. Stay passive, upgrade to an A2200 (which might be needed longer term in any case), then, as funds permit, go for the Akubariks (which will need to be sourced second hand), and only finally make the choice between Aktiv and Exakt - if, that is, the not inconsiderable cost of the latter feels justifiable at the time. If Akubariks really are the desired endpoint, the Exaktbox-I, with only 8 channels, does not provide a viable upgrade path.
Later P.S. If upgrading from the M140s is likely to be a long way off, and you do not have the optional heavier bases for them, I'd invest in those at the same time as you get the new amplifier. They significantly improve the bass performance of the speakers, and will add value (or at least saleability) when you come to sell the M140s on.
