Urgent help needed
Psilonaught
3,776
2,306
Saffron Walden
I need a method to play a DSF file (DSD) via a UPNP app into my UPNP streamer.
I was told to try Mconnect but it doesn't recognise DSD files.
Any ideas? I can use Bubble UPNP but that approach transcodes the audio to WAV.
Gizza
4,794
1,828
Sutton Coldfield
Gary
Does the LinQ support DSF files? From what I can see, Bubble Upnp converts to
If your Dac has USB input and you have an android device, would a direct connection to your dac work, using this app?
https://www.extreamsd.com/index.php/products/usb-audio-player-pro
simon g
Senior Wammer
2,910
2,247
No linger active on this forum
The MConnect app supports DSD. You need the MConnect Player app rather than the MConnect Control, assuming the Linq doesn't use a Converse digital board?
File recognition is a function of your UPNP server; that might be the problem?
I took a quick squint at the Aqua manual; worth noting that DSD64 is max, unless using dual AES or I2S link, when its 128.
Psilonaught
3,776
2,306
Saffron Walden
Thanks Simon.
I am using Mconnect lite player.
The issue is that Mconnect sees the folder on my android phone which contains a sample 60mb *.DSF file as being empty.
