I use the AM stuff too. Also de-ionised water in a spray bottle and 2x microfibre cloths (or carbon brush and 1x cloth).
Spray record with Am cleaner. Clean with cloth. Immediately after (to prevent the Am stuff evaprating and leaving a residue*), I spray de-ionised water on the record. This is then mostly removed with a second microfibre cloth. The record is then left to dry.
Seems to work quite well. A second rinse would probably help, followed by spinning the record to dry it.
This is not for every play- every 3-6 months is probably fine even with regular useage. I use a carbon record brush brofre playing each side. If you get fingermarks on a record, it really needs the full clean.
After cleaning a new-secondhand record, it goes into a new poly-lined paper sleeve. If the original sleeve is printed/has artwork, that is left in the outer sleeve too.
This procedure would also work with the basic 900ml water + 100ml Isoprop alcohol + 2/3 drops of Fairey Liquid (In US use Ivory dish soap) recipe.
*it does- put a drop (or leave overspray) on the run run-out grooves, and it will leave a very difficult to remove residue.
Sorry for War and Peace.
