Often there is a request for any reasonable quality (CD level Flac) Radio Stations well there is one that has been started and is featured on the slimserver forum .
https://jukeradio.double6.net
URL for Flac stream
https://jukeradio.double6.net/flc
Note for mysqueezebox.com Favourites you have to delete the s https for it to work so this should work .
http://jukeradio.double6.net/flc
Now all of this is using LMS and while I am sure it is equally possible to use with other server software I am not able to help with that . There are three streams with varying quality you can choose and on the web site it does give the url for each one that can be copied and pasted in to your Favourites on mysqueezebox.com and then appears in all your LMS players under your Favourites. I find this the best way as it is set up once and once working is then available from all players . There are ways to do this for single players but best to ask for this if you need it .
Once you have the above url set up you can start the station playing but it only shows a very limited details of the song and artist . However if you install the below plugin using the add url field at the bottom of the plugin page on LMS and then enable the plugin (this will request a restart) once completed it delivers the album artwork etc and if you use the Material Skin GUI then it triggers all the details on the information for artist information , album review etc .
http://www.dabdig.co.uk/slimserver-rep/repo-radionowplayingbeta.xml
Music seems to be a slightly limited mix of UK based bands and some blues some of which are rips from Vinyl Albums . Fingers crossed that it will increase the variety of music to include lots of other genres . As there is just constant music with no interruptions this is what is often asked for . As it is free worth a try .
URL for Flac stream
