A very cheap solution are the cork coasters ? Can be found on eBay/Amazon 15 Quid for 50 ? Use as many as is suitable. https://images.app.goo.gl/n7keuspNrrXucPjx6
I used circular cork pads from IKEA under the heads of my KEF 105. All sounds just a little clearer and tighter.A very cheap solution are the cork coasters ? Can be found on eBay/Amazon 15 bucks for 50 ? Use as many as is suitable. https://images.app.goo.gl/n7keuspNrrXucPjx6
I do it cheapish Rohan. If you are happy with the results that's all that counts. I use the thick sorbothane & dynamat too. Would put money towards a v.good quality pair of spkrs rather than alot on isolation. More fun swapping spkrs in & out ? ...but that's just me.I used circular cork pads from IKEA under the heads of my KEF 105. All sounds just a little clearer and tighter.
That's currently not in use as i don't have an item of kit light enough - about 1 - 2kg is ideal for that one. The more recent ones I have posted about are larger and have higher weight loadings, I have seen 2lb, 4lb, 6lb, 8lb, 12ib and 15lb versions (per mount) - the lighter rated ones I think are the best. I have them under TT, phono and pre currently.Have to say I love this thread. How's it going with the Hawker Hunter gunsight stabiliser?
Might get one for my dac- psu is external so it probably weighs a kilo or two at most.That's currently not in use as i don't have an item of kit light enough - about 1 - 2kg is ideal for that one. The more recent ones I have posted about are larger and have higher weight loadings, I have seen 2lb, 4lb, 6lb, 8lb, 12ib and 15lb versions (per mount) - the lighter rated ones I think are the best. I have them under TT, phono and pre currently.
You've convinced me! I don't need any isolators at the moment but I thought it would be interesting to try. One ordered.I’ll keep banging on about these vintage aircraft spring units. This supplier has a reasonable stock of these and have halved their price to just £10. I have just bought 2 trays, that’s 4 spring units per tray. They are NOS, still in their 60 plus year old waxed paper wrapping and the original grease on the springs has kept them in near perfect condition, which makes them a fantastic buy. The spring units are each rated at 8lbs. You need to drill out 8 rivets per tray to separate the mounts.
£10! and they make the engineering on the Nobsound equivalents look positively agricultural in comparison.
https://www.ebay.co.uk/itm/Radio-tray-10AJ-214-for-RAF-aircraft-GB8-/192891038962?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Let us know how you get on. Presumably you may have the option of swapping out some existing isolation for these spring mounts, so would be interesting to know if you can hear any difference.You've convinced me! I don't need any isolators at the moment but I thought it would be interesting to try. One ordered.
The weight rating for each mount should be stamped on the casing. I would expect it to be the same as the ones I received, so 8lb per mount.So the isolation radio tray came this morning. Package still sealed from the year dot. As you suggested isolation units full encased in greas and in mint condition. I don't have a use for it yet but I'll hang on till the need arises. Do you know what weight each of the mounts is optimised for?
Those 9 tonne ones don't come cheap do they? [emoji23]https://www.ebay.co.uk/itm/373043948877?var=641817458631
I have just put a set of these under my whole rack rated at about 20kg each, but smaller ones are ok for speakers.
Basically these are an industrial version of the isoacoustic stuff, not as engineered and probably not as street cred but a good bit cheaper, and wobbly/isolating
Strangely enough I didn't look at those, had they been for my main system I might have
should have said my OLD main systemStrangely enough I didn't look at those, had they been for my main system I might have
That’s exactly the spirit I wanted this thread to be about, chapeaux sir!https://www.ebay.co.uk/itm/373043948877?var=641817458631
The red/pink bit is the actual rubber which is supposed to be in the grey foot bit. But I found it fitted and probably worked better mounted as I have them. They are designed to work on hard floors and be screwed to the floor for permanently fixed machinery. But with carpets I think they are better like this.That’s exactly the spirit I wanted this thread to be about, chapeaux sir!
I saw that you commented on a sales thread about how you used them, would be interested in a few pictures as I am tempted to try these as footers on my rack as well.
mmm... I'm sure it is effective but not convinced we are going to persuade the potential Gaia purchasers looking like this. Is there anything left inside the metal housing? If not you could dispense with it and just sit the rubber on a small coaster on the carpet. I guess the original configuration aims to smooth vibrations from above (i.e. a vibrating machine) whereas under a rack you are more looking to kill vibrations from the floor - was that the thinking? Couldn't you have just mounted the original upside down?The red/pink bit is the actual rubber which is supposed to be in the grey foot bit. But I found it fitted and probably worked better mounted as I have them. They are designed to work on hard floors and be screwed to the floor for permanently fixed machinery. But with carpets I think they are better like this.
Probably not as "pretty" as isoacoustics/townshend etc but they are small at the size I have and are about the with of my 25mm veneered mdf rack foot. They are also lots cheaper.
