The BBC servers are continuing to have problems. If you are lucky enough to start streaming while the server is running it should continue to play. This is impacting both TuneIn and airable Radio who are being directed towards the problematic servers.
We don't believe that this is connected to the changes the BBC have previously announced.
Thanks for the update. I’ve still got the BBC on Airable.The BBC servers are continuing to have problems. If you are lucky enough to start streaming while the server is running it should continue to play. This is impacting both TuneIn and airable Radio who are being directed towards the problematic servers.
Thanks. I know, and use it to Chromecast when listening in the kitchen - not possible to use Sounds with a Linn DSM.BBC Sounds is still alive and well.
You’ll get the Jeremy Vine show which your equipment may play but it may interfere with your wellbeingRadio 4 has been fine via Roon this morning, but that might just be coincidence. Trying Radio 2 now to see...
You’re right. I had to go and have a lie down…You’ll get the Jeremy Vine show which your equipment may play but it may interfere with your wellbeing
How he stays on primetime BBC I will never know - everyone I know turns over when he comes on. I was even in a shop the other day and it was playing BBC2 but as soon as he came on they turned over! I congratulated the shop manager!You’ll get the Jeremy Vine show which your equipment may play but it may interfere with your wellbeing
I still have it all inc. R2 and R3 through Kazoo.I’m resurrecting this thread as the BBC radio channels have recently dropped off airable. Any thoughts anyone?
Edit - just BBC radio 2 and radio 3 that have disappeared. Weird
Does Linn not have BBC Sounds yet?The BBC servers are continuing to have problems. If you are lucky enough to start streaming while the server is running it should continue to play. This is impacting both TuneIn and airable Radio who are being directed towards the problematic servers.
I read last year "Linn DS products do not support the Sounds App"
Yup, there was another issue with Airable on Thursday (or Friday... I forget) but it seems to have sorted itself again
Yes, I randomly noticed a couple of nights ago that R3 was half the usual bit-rate on Airable. So searched for it on Tune-in. Looks like there was a glitch somewhere.I’m resurrecting this thread as the BBC radio channels have recently dropped off airable. Any thoughts anyone?
Tonight my Qobuz is dropping out on hi-res streams, but the modem-router shows 80mbps or above which is more than enough! Hasn’t missed a beat for months. Did the usual everything off then on again - no different! Will probably be ok tomorrow! Time to put an LP on…
No. No suggestion it will either, at least that I’ve seen. Do any streamers have BBC Sounds built in?Does Linn not have BBC Sounds yet?
I can stream Sounds to the DS using Airplay from my iPad, but it’s slightly inferior SQ.
I’ve just tried the BBC ones from Airable’s own listing (not my pins) of Popular Stations. All work except Radio 4 and World Service. How odd!Yup, there was another issue with Airable on Thursday (or Friday... I forget) but it seems to have sorted itself again
Similar threads
- Replies
- 11
- Replies
- 11
- Replies
- 45
