Not that I would listen to BBC, but this thread got me looking into what all is available on my streamer. I did not see any BBC. Is that because I am in the US or am I looking in the wrong place?
Hard to know, not being in the US myself. What service provider are you looking at? E.g Airable, TuneIn?Not that I would listen to BBC, but this thread got me looking into what all is available on my streamer. I did not see any BBC. Is that because I am in the US or am I looking in the wrong place?
If I look at TuneIn, it gives USA, then Arizona, then Phoenix, then…’no stations available’! So maybe the reverse applies?
Not sure but believe on Innuos streamers you can add it, as a plug-in.No. No suggestion it will either, at least that I’ve seen. Do any streamers have BBC Sounds built in?
I can stream Sounds to the DS using Airplay from my iPad, but it’s slightly inferior SQ.
I looked under Airable and TuneIn and didn't see it in either one.Hard to know, not being in the US myself. What service provider are you looking at? E.g Airable, TuneIn?
If I look at TuneIn, it gives USA, then Arizona, then Phoenix, then…’no stations available’! So maybe the revers applies?
Just trying here (UK) although it must be noted that I’m using Roon.
I have set, as radio favourites, Radio 1 Dance, Radio 2, Radio 3, Radio 4, Radio 4 Extra and Radio 6 Music. All play fine at 320kbps.
I have World Service too, and that’s ok, albeit at the much lower bit rate of 96kbps.
Mick
Mick
Thanks for reminding me! Normal service resumed here too today. Full bit rates on BBC, except World Service, as you say understandably.Just trying here (UK) although it must be noted that I’m using Roon.
Mick
Similar threads
- Replies
- 11
- Replies
- 11
- Replies
- 45
