Cable direction
torikoos
3
Kingsteignton, Devon
Koos Fockens
I decided to upgrade some of my interconnects. I do believe that getting a decent pair of interconnects to replace the skinny ones often found with hifi components makes a difference.
Of course everything needs to be in balance. a pair of 200GBP interconnects attached to a 199GBP AV receiver is nuts in my view. So I went for a pair of QED Graphite interconnects between my CD player and my Arcam A85.  They are an improvement over a set of ancient 'Audio Selection' cables I had been using. However on the box it says there's arrows on the cable and to connect it in a certain direction for best results.  That is something I've never heard of before, and I doubt it would make a difference in my case, but maybe I should try it.
I just don't get the theory behind this. Of course if there is a difference in the plugs on one end compared to the other , maybe it has influence on the capacitance / impedance of the cable, but on a 0.6m run, and on a cable that appears identical at both ends?  I'm a bit skeptical.  Thoughts ?
The Strat
13,950
Buckingham, UK
Lindsay
Welcome to Wigwam.  A quick search of the Site will show you that there has been masses of debate about the whole cable thing and indeed strongly held views as to whether changing wires let alone the directionality (is tat a word??!!) can make any impact on the sound.  I'd simply say this if the manufacturer of the cable points the arrow in a certain direction why not follow it.
Enjoy your music.
Regards,
Lindsay
Reactions: torikoos
JANDL100
20,120
7,846
Forest of Dean, Glos
Jerry
On some cables the arrow points to the source component, not the destination component.
Strange but true. :)
Some cables are earthed only at one end, maybe that can make a difference with directionality?
eddie-baby
6,813
3,803
Pembrokehsire
Eddie
Enjoy your music.
Regards,
Lindsay
I would agree with Lindsay.
I personally  think cable direction has no influence on sound, but as electrical energy goes in a direction to a component why not put the arrow the right way and stick with it.
As for sound, cables can have an effect in my experience. How can they not they are all made differently and the materials can vary so much. If you measured them with a meter some would conduct better and some would have more resistance.  As for overall sound think small adjustments on a graphic equalizer type difference, but this has been enough for me to stop liking a system as much (or even altogether).
Higher cost doesn't always mean better for you either.
Interconnects I find make less overall difference than speaker cable IMO. But for an example of two interconnects that do sound different you can get your hands on today, try Van den hull D102mk3 vs Chord crimson. To very crudely put it van den hull sounds dull compared to the chords much brighter sound. Which one you like best would depend on the rest of the things your using, but more importantly the listener if they can even hear a difference.
Nice new interconnects by the way :^ , I like QED stuff.
Reactions: torikoos
whatsnext
534
9
Birmingham
I avoided cables that suggest that the direction is significant. I regard it as taking ME for a ride others are happy to travel on. Cables by Mark Grant and NVA seem to be simple effective cables but not flashy which appeals to some.
torikoos
3
Koos Fockens
Oh I understand there are widely held views on cables etc. I guess the theory of being earthed only at one end may have some effect on electrical properties and therefore sound, but if I hear it on my equipment remains to be seen. Might try it just for the sake of it.   I'm also a believer in quality cables and have heard first hand differences between speaker cable and 'speaker cable' . Once you have good cables, it becomes trickier do distinguish differences and usually only if you really know your gear, the gear itself is of very high quality etc. I think these QED's are more than sufficient for my Hifi where individual components do not exceed 1000gbp.  I'm happy for others to go all out on this, I'm spending the difference on music :)
eddie-baby
6,813
3,803
Pembrokehsire
Eddie
I've been very happy with some QED products myself, and whether its got a arrow on it or not its very well made :^
atomic606
Intolerable know nothing
541
45
taunton
thomas
If a cable has direction markers on it.. No doubt once you have seen them you will hear a difference.
Reactions: mac72
PuritéAudio
Legend Wammer
6,639
1,718
Keith
Imagine what will happen if Roy Gregory finds out you are using your cables the wrong way around!
Keith
eddie-baby
6,813
3,803
Pembrokehsire
Eddie
Tell your partner to swap them around a few times and see if you hear a difference yourself.
I know what my partner would tell me :D
but honestly swapping that QED cable around is not going to make the slightest bit of difference. Even if you had some ultra revealing monitors I don't think anyone could tell, cables yes but direction no. but the OCD in me would make sure they were going in the right direction.
notevenclose
2,557
923
Perth, Scotland
Miles
A number of manufacturers suggest that their cables are not directional by manufacture, but become so in use. Whether this is down to dielectrics, conductors or phases of the moon is open to a degree of conjecture. You might try your cables 'as is' for a few weeks then reverse them and see if you notice any difference.
Unless it's for a specific technical reason (as already suggested) it may be as well to regard the arrows as being purely for connection consistency, although I suppose in the real world users aren't swapping cables that often.
f1eng
2,550
181
Wantage, U K
Frank
Music signals are AC so the idea of directional cables in themselves is absurd. In some shielded cables the shield is only connected at one end, which would mean which way round it was would influence the shielding. Some cables have filters in them at one end so which way round they were would potentially effect the filtering.
torikoos
3
Koos Fockens
Ok, I found my answer on QED's own website:  They write: Electrostatic Screen:  Provides immunity from external high voltage noise signals. Only connected at the source equipment end hence the directionality arrows on the cable jacket.
So that's the reason of the directionality of these cables.
mickbald
844
221
63
Shropshire
Mick
I always place my source equipment physically higher than the amps. That way gravity speeds up the signal path to the amps which must be a positive.
Having said that, is gravity real, or does the Earth just suck :peace:
Speedskater
1,017
285
118
Cleveland, Ohio, USA
Kevin Graf
Yes, some interconnect cables have an added shield that is only connected at the (powered) send end. They don't work so well when connected to a phono cartridge.
For other cables there is an audiophile misunderstanding. They think that the signal leaves the send end of the cable like a train leaving the station and go on to the next station.
But at any instant the signal leaving on one core has an equal but opposite signal returning on the other core. A half cycle later there rolls are reversed.
No members online now.
