You leave us old farts out if it. I am one and listen exclusively to my digital sources. Regards AndrewLet it be clear that I don't doubt for a second that vinyl sounds better to some people. There's a Portuguese forum dedicated to analogue full of mostly old farts in love with old receivers and turntables to prove it. eace:
That's really interesting actually Andrew, I'll take your word for it :^The auditory reception system is a fairly simple but is wired to more areas of the brain than any other sense. This alone makes hearing a complex area to study.
Regards Andrew
I think a better example is directors still adding film grain effects.Do you still watch VHS tapes?
If you don't want to try this for an interesting read https://www.amazon.co.uk/dp/B007N6JEA6/ref=dp-kindle-redirect?_encoding=UTF8&btkr=1.That's really interesting actually Andrew, I'll take your word for it :^
And smoking, do you still smoke things? Surely people only vape these days. I'll have to try some of yours thoughWhat have you been smoking?
Thanks for that - it sounds an interesting book - I’ve just bought the kindle versionIf you don't want to try this fir an interesting read https://www.amazon.co.uk/dp/B007N6JEA6/ref=dp-kindle-redirect?_encoding=UTF8&btkr=1.
Regards Andrew
Yeah that's it. Trouble is there are people who are blindly convinced that it has no place anymore. As you say you get great enjoyment from either so that's all the evidence you/anyone ever needs really.I wouldn't be without either format. Both have their strengths and weaknesses. There are some albums where I will always reach for the vinyl (Bowie), and some where I will always go for the file (Bjork). I try to stick to AAA recordings. They do have a certain magic to them, rarely beaten by a digital remaster.
It does look really interesting actually. With anything like that these days it's always great through the power of Youtube to search the author as well. A lot of the time they are there in some form and you can actually listen to them before you buy as it'll give you a good insight before you start reading their books.Thanks for that - it sounds an interesting book - I’ve just bought the kindle version
You can add analogue effects in digital audio too. Some plugins emulate the sound of the most famous analogue studio gear.I think a better example is directors still adding film grain effects.
Not heard the best TTs but have heard a few good ones. Good tonal quality is there though as you say with playing records.am yet to hear a digital front end that has the resolution *and* tonal qualities of the best turntables that I have heard
Maybe, maybe not, that digital is more accurate as lack of universal agreement on definitions blah blah blah. Regarding tonality, you yourself said upon receiving your new DAC, something along this lines that the resolution was much greater than your previous one and that some people may consider adjusting their playback system in someway to compensate.Tonal quality is part of the recording. A good source is the one which will best reproduce the recording.
There can be enhanced tonal quality (usually the result of low order harmonic distortion) and damaged tonality (usually the result of uneven frequency response).
Digital has (potentially) far more resolution than vinyl. It's a lot more accurate.
I recommend this 2 page piece by Jim Lesurf titled Good Resolution which compares vinyl and CD:
http://www.audiomisc.co.uk/HFN/goodresolutions/page1.html
http://www.audiomisc.co.uk/HFN/goodresolutions/page2.html
Fixed that for you.Tonal quality is part of the recording. For me, a good source is the one which will best reproduce the recording.
That will be expectation bias then.I believe there is too much thought put in to this.
If the perception is that digital sounds digital then it will
since buying an m-scaler I think those digital irritations are now a thing of the past for me.
This is what I have found. The 44kHz cap is the limiting factor. Once it is removed you have the best of both worlds.
