Not sure this needs much in the way of introduction but in case you haven't heard of it it's one of the world's better amplifiers.
Seldom available second-hand, in fact I bought this myself second-hand and was highly berated by my wife for purchasing it but I knew if I didn't buy that day I would never see one again I could afford!
[/IMG]
[/IMG]
Anyway, stats below:
Inputs: True Balanced (XLR), Input Impedance 36kOhm
Single-Ended (RCA), Input Impedance 18kOhm
• Input Sensitivity: 2.15 Vpp 200W (High Gain +34db)
4.3 Vpp @ 200W (Low Gain +28db)
• Max. Linear Input Range: 5 Vpp
• Max. Input Voltage: 20 Vpp
• Transistors: All Bi-Polar
• Feedback: Zero Negative Local & Global Feedback
• Damping Factor: 80
• Signal to Noise Ratio: >120 dB
• Power Rating: 200 Watts at 8 Ohms; capable of driving a 2 Ohm load
• Static Power Consumption: 320 Watts
• Filter Capacitance: 249,600 uf
• Common Mode Range: +/- 20 V
• Transformer: Single 1000W Toroidal Transformer
• Dimensions: 17.5″ wide x 12.5″ deep x 8.5″ tall (including feet)
• Weight: 75 LBS
• Control Features:
– Switch for Balanced or Single-ended operation.
– Lighted switch for Standby and Power
– Jack for remote power on and of
If you've got any questions please fire away, I am only selling this to upgrade to the Monoblocks, this replaced an MBL poweramp for me and, honestly, it was so much better it surprised the hell out of me.
If you go MSB you won't go back…
£5500 + exotic delivery or personal delivery to you if you live anywhere on the South coast or within reach of Hampshire. (New price £14,600)
[/IMG]
[/IMG]
• Weight: 75 LBS
• Control Features:
