Is there a phono stage manufactured that allows impedance/capacitance adjustment without add gain to the signal so it can be connected to a phono input?
Pioneer SA 9500iiWhat amplifier are you using ?
Cracking amp , very musicalPioneer SA 9500ii
A slight aside. A few years I did minor fettling - cap replacement - on the phono stage of a Technics SU-8080. About the same age as your amp.Pioneer SA 9500ii
Yes I love it. Have been thinking about finding someone to give it its 40yr service.Cracking amp , very musical
I have a pioneer SA 706 from the same era ..
It's probably worth it. I did the usual - DC offset and bias. Barely needed touching tho'.Yes I love it. Have been thinking about finding someone to give it its 40yr service.
When I took the 706 in for a service and to have new bulbs fitted in VU meters the guy said it didn’t need anything doing to it and the components where as good as you could get ..Yes I love it. Have been thinking about finding someone to give it its 40yr service.
Trouble is I don't like moving it too often as it's about 20kg, I have it on the bottom shelf of a double wide TV / AV RACK and it has bent the metal box workYes I love it. Have been thinking about finding someone to give it its 40yr service.
I'll beg to differ slightly. The aforementioned Technics amp had 2 settings for resistive load - 47k and 33k. The 33k certainly didn't sound right, so I'd leave the OP's at 50k.The 50k is normal, but the resistive loading shouldn't really make any dfference.
I'm sure your ears are fine . It's what works for you and your system.Lowering the cap I found the treble a little muffled, maybe it's my ears? But definitely had more clarity in the mids at this value
