Logging out and back in will cure thatHad some issues yesterday where it was skipping through songs as if playing a taster of each one
Try the log out and back in routine. If you're using wireless, try temporarily connecting via cable to your router and see if that helps. If it does it's your wifi network.Mines just buffering all the time. 30 seconds before song comes on and not playing through albums. And ‘error not connecting with qobuz database’
Thats because you are not signed in or subscription has finished. If signed in, then logoff and back in, should fix.Had some issues yesterday where it was skipping through songs as if playing a taster of each one
Thanks. Having spent time yesterday listening to records it was working fine today without having done anything.Try the log out and back in routine. If you're using wireless, try temporarily connecting via cable to your router and see if that helps. If it does it's your wifi network.
