Who is the admin for Classical section?
josh
1,144
78
NW London
Hi there, as per title, if we want a thread pinned in the Classical sub section, who should we ask?
Thanks,
Josh
Cambs12
9,179
7,820
Cambridgeshire
Stuart
This one: https://www.hifiwigwam.com/forum/topic/98420-the-definitive-bach-thread-list/?_rid=54134
Which actually I was about to post another question on. The links in that thread no longer work after the forum crashed a few years ago. Is there any simple way of converting the links to whatever works now, or do I have to manually go through and find the new versions and update the post?
Hi Josh.
I think you will have to go and do it manually I'm afraid. As for pinning a thread in the classical section, which one do you want it applied to?
Bazzer
31,086
Ok josh this what you'll have to do :
Go into the Classical section and use the search function , make sure you select thread Title Only , open the thread copy the URL and replace the faulty one URL with it .
I have just done the three Goldberg Variations threads in your list , try them  :^
Reactions: Cambs12 and garn63
