I've moved them around a few times to no avail. I would have thought if it were just dirty pots, when moving them there'd be at least some scratchy sound?
I'm afraid you're right. It does sound like the tweeters' voice coils are open. It's a well-known fault. Don't blame yourself for not noticing immediately either. The midrange driver goes up quite high, so the whole top end wouldn't be missing. If you turn the midranges off on a pair where all three drivers are working you basically get the bass plus a tizzing noise from the tweeters, and that's all they do. Apparently people have gone for years without noticing that theirs have blown.I've moved them around a few times to no avail. I would have thought if it were just dirty pots, when moving them there'd be at least some scratchy sound?
I can do a bit of SMD soldering' date=' but I fear if I tried to dissect the tweeter I would myself end up making it worse (if possible). Is there anyone in the thread who'd be willing to have a look at the tweeters for me? [/quote']
If you decide to hang on to them I'd be happy to have a poke round the tweeters for you.
I paid £550 for them and got the grills, so I did really get a fairly good deal. I was just disappointed as the cabinets are beat up and felt £550 was a fair price because of that alone.You need to test them first, do you have a multimeter?If so, remove the tweeters , disconnect the wires (these may have to be cut as mine were soldered on in the factory) then test with the multimeter, they should read around 7 or 8 ohms if working correctly.
This is the first step and will determine the next line of action.
If the ribbon wire making up the voice coil is broken it isnt the end of the world and it is an easy fix, just very fiddly.
Test them first with the multimeter and let us know how you get on.
Edit - This is how I repaired mine, you may have to register to see the photos.
http://www.audiokarma.org/forums/showthread.php?t=477605&highlight=pitabread
Can I ask how much you paid for them? If you got them cheap enough then repair them, if you paid top price for them I'd be chasing my money back and waiting for a working set to come along.
Have you tested it yet? Test it before stripping it.How do you remove the grill?I can't make it budge! (Tweeter is out of the cabinet and on my bench, rubber going around the mesh will not move, nor will the mesh itself.)
I take it you tested the resistance on them and they are open?I have a good Weller Iron with a tip meant for SMD stuff. Amazingly I also have a little iron block with a magnifying glass on them, so i have the tools.I just cannot work out how to get the mesh off of the tweeter
Yes, 0 on impedance testing with the multimeter.
