Apart from pink, those other criteria aren't actually that bad.So.. pink, quite tiny, easy to dust, only one knob to turn on and off.....
I once had a 7 box amplifier that even I struggled to turn on in the right order.
Looking forward to the write up after your visit.No he doesn't have one and I'm not carting this up stairs at Scott Towers. Not sure where that leaves us. I think it will be a fresh start, with my Mrs ears!
You won't get universal agreement on this. Many like tube amps exactly because they don't have feedback loops. Yes, it may tighten the sound but at the expense of other side effects. In fact, designers like Nelson Pass have tried to reduce feedback in solid state Class A amps as much as possible, since it can sound more natural.All SETs should have variable negative feedback control so you can better match them to your speakers.
Yes with push pull that could make sense.I prefer SS amps that have no global negative feedback-Dartzeel and Bakoon for example.My amp is a 300b push pull with three different feedback settings. I prefer the zero feedback setting as to me it gives an open wider soundstage.
Cheers Ady
I've had a few friends bring their se 300b amps around to mine with a variety of valves, that flabby bass, was obvious (even with my 100db speakers) in varying degrees with just about all modern production valves.Cathode degeneration of the driver valve is about the only SET feedback I have found generally beneficial, but high output impedance and flabby bass is a scourge of SET topography, sad to say.
+/-3db 40hz - 30khz.A typical frequency response of a 300B SET using zero negative feedback.The green line is for a simulated 8 ohm speaker load .This was a Mastersound 300B.
A very long way from a flat response.
300B's worked beautifully with Kevin's new R80 speakers at Scott towers.I mentioned before the Magic of pairing my 300B valve amp with Snell A speakers.
You've got to get the speaker synergy right with 300B tubes and then magic can happen.
I suspect that it's just that much rarer with 300B than many other valves. It can be well worth persevering imo.
