DSP or any EQ is simply about EQing the system - there's no difference between PA or hifi with regards this requirement. It's all about whether the corresponding biquads have been preconfigured within the signal processing.Anyway, according to the najda software page
http://www.waf-audio.com/products.php?pos=1⊂=4〈=en it
does have shelving (I thought I'd remembered that)
If you compare the red plot to the green plot in your graph, then by eye the green plot seems to +5dB from about 5k upwards in comparison to the red plot
My comment was referring to what I assume 'they' do to PA X/O's etc to prevent tweeter damage at very high vols. PA boys don't aim above 15K or so as it sounds rubbish at those vols anyway.
I assumed shelving meant for the bass and treble mode - with that off should be ok. If this is the cause of my dB robbery with it disabled - it rather sucks!
I have been playing and testing and still prefer the caps/passives on the compression drivers to anything coming out of Najda X/O wise.
So far best combo is Najda X/O on Tapped and Mid Bass with sparing use of cutting only correction to tame room modes.
Mids, Upper mids and Tweets on passives fed though Najda with the X/O's off - no correction. X/O's for Tapped and Mid bass tuned to give best measurable response.
Sounds totally acceptable. Playing SPU/FR64s/SP-10 into it now - nice. Bass was good before - it is rock solid and as I want/like it now.
Next round of measuring and playing will be time alignment for all channels in Najda to see how that affects things - Could be positive from time aligning POV or mush things up from DSP having to work harder POV? Lets see.
