Has anyone got experience of fitting a Kuzma 4point9 arm on a Nottingham Hyperspace? I’m currently using a SME 309 and fancy a Kuzma and trying to work out how straightforward it will be to change.
Wow that’s going to be some upgrade. Please let us know how you get on.Has anyone got experience of fitting a Kuzma 4point9 arm on a Nottingham Hyperspace? I’m currently using a SME 309 and fancy a Kuzma and trying to work out how straightforward it will be to change.
Good idea, thanks. I'll talk to the NA people as well, they may have some experience of thisYou should be able to fit a 4P 11" on a 9" std arm distance due to the arm offset from the VT tower. The hole Dia I believe is 30mm. Just check the spindle pivot distance on the kuzma site then temporarily set your 309 to that. If you can, then all should be good with minimal rework to the original armboard.
Will do! I've heard great things about the Kuzma'sWow that’s going to be some upgrade. Please let us know how you get on.
I nearly bought that arm but as I decided to try streaming I used my spare cash in that insteadGood idea, thanks. I'll talk to the NA people as well, they may have some experience of this
I've been on the same journey. Spent way too much on an Antipodes streamer and switches etc, but I've got to say it sounds very very good. Now to give the TT a bit of loveI nearly bought that arm but as I decided to try streaming I used my spare cash in that instead
Thanks for sharing. I've spoken to Penny @ NA and she's making me a top plate for the armboardHere's a manual with all the mounting details.
It’s a 40mm mounting hole at 212mm spindle to bearing.
Just installed one on my kuzma reference 2 deck and it’s fantastic.
I intent to try my 4.9 on a Linn LP12 but the weight of it might prove the issue.Sorry to hijack but has anyone fitted a 4point on a suspended deck, something like a Voyd reference or a AN TT3?
The 4.9 sounds superb on my ref 2.I have the Stogi Ref 313 VTA on my Ref 2. Sounds fantastic but would love to hear the 4Point on there one day.
I’ll be interested to hear how your experiment works outI intent to try my 4.9 on a Linn LP12 but the weight of it might prove the issue.
I’ve cut the arm board but wanted to get familiar with the arm first on its intended deck. I’ll post my observations when I try it.I’ll be interested to hear how your experiment works out
Thread resurrection, did you get the 4.9 arm, how is it, wondering about one for my Stabi SThanks for sharing. I've spoken to Penny @ NA and she's making me a top plate for the armboard
I did and it’s very good indeed. More dynamic than my 309 which goes well with the Hyperspace. VTA and Azimuth are super easy to adjust. The floating feel due to the 4 bearings takes a bit of getting used to. Should be a great match with the StabiThread resurrection, did you get the 4.9 arm, how is it, wondering about one for my Stabi S
Very nice. Kevin at Definitive recommended the red with the 4.9 and I generally trust his choicesThanks, also toying with the reference version of the stogi
