Ah, this is a very pertinent post for me!Whilst I like my speakers very much and feel that they do bass pretty well for what they are, spec is down to ~32Hz, allegedly, I have been just starting to think about maybe considering an upgrade. Now, I don't box change very often and I've only had my GR20's for 5 years so it seems a bit soon to be changing.
Anyway, I stumbled across an old post that was resurrected last December regarding the most recent Proac range, featuring ribbon tweeters and carbon fibre mid-bass units. As the technology is always of interest to me, light and rigid CF seems like a good starting point for some cone material, and likewise the extremely low mass of ribbon tweeters also appeals for HF performance.
So, those very nice people at Unilet in New Malden let me come and listen to a pair of D30R's and also some D20R's, alongside a pair of PMC 24's.
Well, the D30R's bass is really quite amazing. Nominally down to 20Hz and really revealing on a couple of bass test tracks I use - Loving Arm from Metronomy's English Riviera and No Comprende from Low, Ones and Sixes. However, their demo room is quite a good size, compared to my home room which is pretty tiny - about 14ftx10ft, give or take. Plus, the D30R's are £4k7 :shock: Having said that, I haven't seen any other specs that come close from other manufacturers below about £8k - making them almost good VfM!!!!!!! :shock:
It had led me to start thinking about a sub, but I've got no experience with them and no sub-out or anything like that from my amp. Sounds like integrating a sub with my existing GR20s may not be straight forward.
If you're going to set a subwoofer crossover to 80Hz, then also roll off the mains at 80Hz so they don't try reproducing anything that's being sent to the sub. By doing that, you'll be reducing distortion considerably and increasing power handling so the mains will go louder without distorting. This assumes enough headroom on the main amps, and a low distortion sub, but that's the right way to do sub-sat systems, in my view.I prefer larger three way 'speakers than a sub-sat system, as I can't get on with mono bass. There's something wrong, perhaps near the crossover where bass goes from being mono to stereo, that I can't specifically identify, but I've never found a single sub that satisfying.
S
Fill in your kit list or say what the current speakers are?It's the most common problem in HiFi...trying to sort bass response in a room. The answer IME is far likelier to be that your current speaker/room interaction is horrible, and throwing a different bass making machine at the room won't help (you can easily move a sub around, which is good, but as you have found, subs tend NOT to be designed for HiFi useage, more for AV and party work. Some exist that are specific to speakers (horns for example) but these cost a small car).
Maybe the best answer is to buy speakers which really do do bass properly and then tweak the room acoustics to suit them?
The 'proper' way to get bass is with a lot of bass cone area..one or two 15" drivers per cabinet, or 4 8" ones and then an amp with a steel fist of control...something large, probably class A, preferably american monoblocks.
Have a look at a Velodyne DD sub.Run a monitor from the sub.
Very tuneable...
I wouldn't use a subwoofer with large floorstanders unless I enjoyed a specific type of demanding music - reggae, dubstep, organ music, that sort of thing. Even then, I'd cross it over at about 40-50hz so it's only doing the real low stuff. For most music I much prefer the tightness and integration of floorstanders on their own. Most can easily delve deep enough. I'm listening to my Kefs now and I'm definitely not wanting for any more bass. For AV use my speakers are all crossed over at 80hz with the sub, but LFE effects are a different kettle of fish, and my 2ch system is separate if need be anyway.
Damn right!Subs are for wimps. ;-)
You just have to make sure you've got an amp(s) with enough gruntMy experience so far backs up what you are saying but when I read stuff online it always claims that "subwoofer X produces outstanding clean, fast bass" and that to produce deep notes you need a lot more power to control the speakers. In theory a specialised speaker with a large amplifier ought to be able to produce faster, punchier bass than your average floorstanders with their lower powered amps and resonant cabinets. I was hoping that in the real world this would also be true but so far I've been disappointed.
Dylan - if have a look at the DIY section on this Forum I think you will find a number of members who cannot be said to be members of a 'herd mentality' belonging to this or any Forum. In particular I'm referring to we Horn System enthusiasts who are forced into 'doing it for ourselves' because very little exists in the conventional marketplace that satisfies our needs for sensible money.Horn bass can be had for reasonable money if you can house it. Its not pretty and its not unobtrusive but a PA touring subwoofer in a typical folded horn cab with an 18" driver can be had for £300. I bought 4 of these from the Happy Mondays touring system for £800.
I realise the thread assumes a 'domestic-style' system -either AV or 2 way - but there is another way.
Jack
You just have to make sure you've got an amp(s) with enough grunt I've yet to hear a sub that produces bass that's as clean and fast with music as a set of sizeable floorstanders. Deep, sure. But like I said, to me certainly, bass requirements for music and AV are different.
