I know what you mean.its times like this I wish I wasn't an audiophool
Eh ?!All it should come down to is a good amp, the best speakers you can afford .. a half decent source .. then forget about it
The specification - materials, size, construction - seems to be the same as Signature speaker cable.mosfet wrote:Which cable in the Chord range do you think that is used for ?
I think you will find Chord Signature speaker cable comes from China (just a guess)Davewhityetagain wrote:The specification - materials, size, construction - seems to be the same as Signature speaker cable.mosfet wrote:Which cable in the Chord range do you think that is used for ?
ta was it you who told me about that company in china ? memory playing up big timeDave,No these are not the said cables.
I will try and find a picture of some, only one of our clients uses them (we do not supply or have anything to do with them)
well, I worded that badly .. I mean inexpensive .. digital can now be doneso well so cheaply (as you know - with the beresford)nixon_fiend wrote:Eh ?!All it should come down to is a good amp, the best speakers you can afford .. a half decent source .. then forget about it
Rubbish in - Rubbish out.
Front End First.
Ecoflex10 is one of many RG213 co-ax cable variants. All RG213 types have the same basic specification - those with dual screen and foamed dielectric are one variant. None cost more than a couple of pounds a meter. Until that is you add some techflex sleeving and a load of [cough] marketing. I’m sure Chord are not the only cable vendors doing this.It would be very interesting to make up a knock-off out of satellite TV aerial cable and blind test it against the chord....
Why did you "need" to have townshend for different lengths ?lol! you lot are mad as a box of frogs! just to let you know I'v ordered a pair of townshend to be delivered over the weekend..these were very reasonable as I need 1 short and 1 long length as as most go for an equal pair this was on pair (well a bit more) with a decent length eBay/used pair. Full report over the next few days!adios
