I've seen it used in bolognese recipes so I thought I would give it a try in a pizza sauce recipe and it seems to work.Hmm ...... bit of sweet and sour ..... ..
I also don't use cheese and prefer them that way.
Hi Darren, I used to divide the dough into portions and freeze them with no issuemade my first ever home made pizza last night. (first time making the dough, tomato base and everything that is.....)was awesome! should have taken pics really, but forgot in my haste to scoff!
i can see this becoming a bit of an obsession. does anybody know how well pizza dough freezes? (if it does at all)
Here you go boys ........ the Jamie dough recipe is fine ..... I don't make as much as the recipe says ...... I stretch my dough out on chopping board with marks on giving me max size for oven shelf thing ,,,,,,, I then put shelf thing on top of pizza dough and turn chopping board upside down thus transferring the pizza dough to shelf thing you know when things are right when dough is a bit like stretch armstrong .........Then put your toppings on ..... I make my own tomato toping by frying finely chopped onions ..garlic ... a bit of chilli ... pepper ..salt ... in olive oil and adding chopped up tinned tomatoes ,,,, red wine and tomato paste .... reduce till you've drunk most of the chuffing wine ......... and it's time to stay away from anything with stylus ...
Spread topping on dough ...... add your main toppings now ... Its a good idea to buy a antipasti meat pack cheap and get a mozzarella ball remember less is better ..... don't add to much as will stop pizza cooking ..... too much moisture now is the enemy .....
Don't be a nob and worry about how round it is ........ shove it in oven at 250 or more if you can .... gaze though glass bit of oven till it's done ...
[/img]
A friend of mine used to work at a nearby Italian and the first job in the morning was firing up the wood burning pizza oven. It used to take hours to warm up and be ready for use. The type of wood used was also important, not any old wood.There was an interesting thread on PFM a while back where someone had built an outdoor pizza oven. This was ideal for getting up to the kinds of temperatures that are needed to really cook them quickly as you might find in a proper restaurant. A conventional domestic oven generally only gets up to about 250 C.
The problem was the amount of fuel (wood) required to get this oven up to those temperatures meant that it was only really practical to fire it up if you were having a party (bakeoff?) & needed to cook 20-30 pizzas. Time & cost ruled it out as a sensible option for cooking just one or two.
No worries ...... make sure the pizza base is floury underneath .... place the rack on top then turn the whole lot over then lift the chopping board slowly up ... the pizza should un peel from the board with a little help .... I've tended to use this method quite a bit and I get a well cooked base ....Thanks for the tip.For me, I make dough, load it with toppings, then its an arse to get thin base into oven. Your pic shows to put base onto rack before loading with toppings (pic 2).
Cheers!!
