Cheers John. At the moment the panel vertical centres are 60cm from the side wall (should probably have explained this better earlier, when I said 75cm from the side wall I meant the inner edge of the panel). I don't think I can move them any further apart or they will be too close to the side walls.
I don't currently have anything like that much toe-in, but I will definitely give it a try to see how the imaging / focus alters. I know the bass levels will need to go down from the current (flat) settings and I'll start with similar settings to yours - I suspect I might need to take the 50Hz down more than the 25Hz same as you, but I'll wait a bit to alter them. I don't want to rush into too many changes or I think I will end up confusing myself (doesn't take much! ha ha)
Currently I am thoroughly enjoying the Summits even in a rough & ready setup, they just reward so much with their presentation. It's really quite different to what I've been used to, no surprise, and I can't yet articulate precisely what I am hearing, but I'm sure I will soon be able to put it into words. I know they're not everyone's cup of tea but they have such musicality - I am having more and more "goosebump" moments when I listen, discovering more details and texture even in music I thought I knew well. I thought my C500's were great at pulling out more detail, and I don't want to trash their reputation because they truly are a great speaker, but the Summit's character and presentation is just on another level altogether. Probably ought to be, given the price differential, even considering the difference in age. (mental note, must check the serial numbers with ML to see how old they actually are)
I am aware that my front ends will need some upgrading, but then I kind of intended / expected that prior to purchase. What's important right now is that I can live with what I have and plan the next steps without rushing into things. It's definitely going to be a new cartridge for the analogue front end however, and probably some mods to the phono stage too, while the digital side of things might get replaced altogether. I must also get some new mains cables for the speakers, mainly because the positioning of the nearest sockets is awkward and I want to plug them in elsewhere (and I do unplug them each night after use). I think I'm going to try the Puritan ones - I am not expecting any perceivable changes in sound but I'm just looking for something of the right length and a decent quality.
Right, back to the music, gents! More soon
