£200k in GB...Interesting. And a bargain at only $169,500 a pair for the Lyras :shock: .
I was suggesting using a microphone to measure the pressure inside the speaker cabinet, by actually putting it inside the speaker. Although you might find the pressure levels exceed the maximum the micophone can be used for.With a 25Hz tone through the driver I can feel air escaping through a couple of panel gaps ….these will be filled/sealed as I now have time before March 22.
I wasn’t suggesting that a pressure test could replace any other testing …..it was just out of my image curiosity to see how much pressure was created inside the cabinet to generate the air escaping from orifices other than the port - they must have detrimental effect.
I had a quick look but couldn't find anyone selling them!£200k in GB...
Oh, and at the risk of pointing out the obvious, be very cautious about playing about with tones at this sort of frequency as it's a good way to burn out a driver if you're not careful.With a 25Hz tone through the driver I can feel air escaping through a couple of panel gaps ….
Are these guys in your vicinity?I had a quick look but couldn't find anyone selling them!
Looking very niceJulian - Bigrod gave me some great advice on finishes for the yellow balau, using tung oil so this weekend I decided to start on the hopefully final surface finish. As you may recall it’s a tropical hardwood vv dense (30% more than Russian birch ply) with a very tight grain structure.
Trying to produce each panel from 140mm planks with biscuit joints etc was a challenge and the wood has ‘moved’/ cupped so I found a vintage Wolf belt sander off eBay than had the grunt to attack this wood.
Two hours of sanding with 80 and 120 grit belts gave me a good flat surface and then as recommended by Julian, I hand sanded it down to 400 grit then a tack rag (to remove all the dust), wipe down with white spirit, then using a lint free cloth applied a 50/50 mix of pure tung oil & white spirit.
Wow the grain really stands out now …but this morning I flatted it off again and applied a 75/25 mix. I’ll let this harden off for two weeks (mainly as I’m away with work next weekend) then it’s two more coats of 100% pure tung oil.
how are the cabinets coming along?Just noticed I’ve hit 25k views …..amazed at the interest in this thread ….thanks one & all
To be fair, 24,500 of them have probably a been from me checking back in regularly to see if you have uploaded the long promised video of the bass ports blowing out a candle half way across the floor.Just noticed I’ve hit 25k views …..amazed at the interest in this thread ….thanks one & all
Ive used the wire wool when restoring an antique pine chest of drawsBig ports do not make good candle snuffing systems.
In the mean time I took delivery of some 0000 grade wire wool to see how a real burnished finished would look on the Balau. So this afternoon I smoothed off a 50mm strip off the top of the cabinet with the 0000 wool - wow ultra smooth now and then a quick wipe over with some danish oil and it’s silky smooth and ready for some high quality wax.
lots of use of wire wool planned for this weekend I think
This is the only build thread, that I've ever thoroughly followed through all 44 pages and still counting till Kegworth or the newer venueJust noticed I’ve hit 25k views …..amazed at the interest in this thread ….thanks one & all
You just want to watch Keith getting them out of the van don't you Like a big unboxing fetishThis is the only build thread, that I've ever thoroughly followed through all 44 pages and still counting till Kegworth or the newer venue
