A weeks absence from here ( not a ban ....damaged iPad and password issues) let me sort a couple of other bits on the Volts.
Between rain showers etc I managed to get the 18mm plywood cut and drilled (25 counter sunk fixing screws per sheet) to fix to the rear baffle of each speaker, which was 'only' 30mm MDF. The aim of this was to be both visually finishing off the rear and brace/seal the baffle.
A good layer of wood adhesive as applied to the MDF then on with the ply and 25 torx drive screws.
Before any critical listening I decided to allow 24 hrs for the glue to work it's magic and then it was out with someone me reference tracks. Bass seemed deeper and the decay was more detailed. Not had chance to check with REW or take pics as I'm away with work again .....maybe this weekend.
