As long as network cables meet spec, plugs fitted with adequate strain relief will probably do more to aid data integrity/ensure everything is working than all the fundament smog being blown up your jacksie by foo peddlers.Some while back I was using a cheap Belkin patch cable with none existent strain relief* to connect my SBT to my router (*none moulded push fit plug) & would sometimes lose connection/get buffering issues which a little jiggling at the connector would sort out. It is worth pointing out that at the time I bought this cable from Argos that the cable shown had moulded plugs, I was pissed off at the time & but for the need for a cable there & then would have returned it.
I've since started using these, which are cheap from Amacu***z & even a 15m run only costs £8-49>>>
Duronic 15m Professional Gold Headed Network Cable - Black - High Speed Premium Quality Cat6 / Patch / Ethernet / Modem / Router / LAN
I knew that if I read this thread for long enough that you would be on to offers some sound advice. Thanks Chris. :^
