Finally got my hands on some Audio Technica AT607a stylus cleaner fluid on Saturday
I decided to do a little experiment over the weekend to see how clean the Dustbuster keeps a stylus which I use after every fourth side. I know it removes any dust because you can see a tiny fleck on the black surface but is there other more stubborn dirt building up over that time?
On Sat late morning I started by using the fluid & brush on my stylus then gently dabbed it very carefully with a bit of tissue to dry it & see if any grime came off. There was a bit of discolouring on the tissue showing there was some grime/dirt on the stylus. I then played my music thru the day as normal using the dustbuster as usual.
On Sun morning I cleaned my stylus again with the fluid and brush once again dabbing the stylus to dry it and again found some discolouring on the tissue not as much as on Sat on the first clean but it was there for sure. I have done the same over Sun and into today to get a similar result again but again a bit less.
I guess my conclusion is obvious there is a place for gentle/careful wet cleaning of your stylus after maybe 8 to 10 records (16 to 20 sides) I should also mention all my vinyl is washed & vacumed put into a new sleeve before being played wether new or 2nd hand also I have never felt the need to repeat the cleaning process again on my vinyl.
Please draw your own conclusions.
